Has anyone managed to get Jawawa to see a USB-connected XT2? I have had excellent results from Jawawa on older Garmin GPS units. I connected my XT2 to my PC today, windows saw it as a drive, but Jawawa said that it could not see it.
Thank you
Jawawa and Zumo XT2
- Has liked: 65 times
- Been liked: 172 times
Re: Jawawa and Zumo XT2
Windows will only see an XT or XT2 as a media device, not mass storage. Windows will not assign a drive letter, which is what JaVaWa requires.
I seem to remember using a JaVaWa utility to modify some map names by copying the map to a USB stick, running the utility to modify the map, and then copying the modified map to the Zumo.
thanks much. That explains why jawawa doesn't see it.
Grant Wilkinson
Ottawa ON Canada
Ottawa ON Canada
- Been liked: 2 times
This is the answer from Jaco at JaVaWa on my question why it dosen´t work wit XT2.Hi Anders,
The zumo XT2 (and XT) use MTP exclusively, JaVaWa Device Manager cannot acces them. There is no workaround for it.
Regards,
Jaco
Anders
