How to tell if ZumoXT is fully charged
For everything Garmin Zumo XT related
semmyroundel
Has liked: 20 times
Post by semmyroundel »
Hi all, I took delivery today of a Zumo XT. It's been on charge for over 8 hours and it hasn't said : fully charged or the battery symbol being FULLY green once lead unplugged.
I do have a 2amp+ wall charger, and it has been on standby all that time.
How can I tell a percentage charge? Is that possible?
Has liked: 268 times
Been liked: 142 times
Re: How to tell if ZumoXT is fully charged
Hi and welcome to the forum
Sometimes mine doesn't show fully charged but it is!
Press and hold the battery icon for around 5 - 10 seconds and a screen will open with a lot of info on and when plugged in it will tell you if its charged or charging
electro_handyman
Been liked: 15 times
Post by electro_handyman »
As with most electronic and internal batteries, it may take a couple of charge/use cycles before the battery reaches it's full potential.
semmyroundel
Has liked: 20 times
Stu wrote: 01 Aug 2021 18:47 Hi and welcome to the forum
Many thanks, I'll give that a try!
semmyroundel
Has liked: 20 times
electro_handyman wrote: 01 Aug 2021 19:26 As with most electronic and internal batteries, it may take a couple of charge/use cycles before the battery reaches it's full potential.
Good point, I hadn't thought of that!
semmyroundel
Has liked: 20 times
Thanks, there's a lot of info there, but the most likely is: BL70%DC
I'm assuming that means 70% battery, now after 9+ hours of charging.
What else should I look at to see what sort of current my charger is able to deliver etc?
Or should I charge/discharge a few times before making any asessments?
No BL is backlight if you press up and down it will change and the screen brightness goes up or down
You should see the words charged or charging depending on what it's doing
Obviously when plugged in
Has liked: 40 times
Been liked: 13 times
Doesn't tell you how charged the unit is directly, but does tell you how much charge it's accepting:
https://www.ebay.co.uk/itm/184974175487 ... SwYuBhBRGS
Has helped me ditch a faulty lead.
cr0100
Been liked: 11 times
Post by cr0100 »
Is there any way to get out of that mode besides power-cycling the device?
cr0100 wrote: 03 Aug 2021 17:42
Not that I have found!
Who is online
Users browsing this forum: CommonCrawl [Bot] and 2 guests
