In another post I ruminated about poking around in the Garmin Explore website, wishing for a web-based routing app, yadda yadda. As expected, it was a failure; you definitely need to have a compatible device to access the Explore website. Moreover, it may then be behind a paywall.
During some exploratory and unproductive poking about I got a wild notion that maybe there was an Android app that might work. There is and I was able to install it on my Chromebook and set up an Explore account. However, you still need to have a device to access it and most of the devices I have never heard of. I think they are watches and fitness pieces and bicycle GPS and bowling ball trackers. However, the last item in the list of compatible devices is the zumo XT!
A footnote accompanies the mention of the XT: "zumo XT comes pre-installed with Garmin Explore information. The Drive app syncs the Explore data and is not compatible with pairing to the Garmin Explore smartphone app." I understand the first sentence. The second is gibberish, even though I know all the words.
My XT is supposed to arrive on Friday. This Explore app will be one of the first things I look into.
Chromebook, Explore, zumo XT
- Has liked: 11 times
- Been liked: 15 times
Re: Chromebook, Explore, zumo XT
Tom Schmitz wrote: ↑11 Mar 2020 04:04
.....bowling ball trackers.
Love it!!
If you think it's difficult, and you obviously have more than a smidging it IT knowledge, then imagine what it's like for us numpties
I messed about with the Explore app a bit. I was able to download a couple of mapsets, both topographical and OpenStreet. I noticed one error in the OpenStreet map that was changed on CNNA years ago; take that for what it's worth.
Once loaded, it was easy to navigate around the maps, though I had to use the touch-screen to do it. Menus and Instructions are all but non-existent. This is rather to be expected of any handheld device app. I could make a waypoint, a start and stop point, and create a route. The route would not route, though, and I am not sure if I need to learn more about the app, about its maps, or if the routing won't happen until a device is connected.
I'm going to work on the two former items but suspect that the thing will not work right until a device is connected/registered.
I am now better able to understand "zumo XT comes pre-installed with Garmin Explore information. The Drive app syncs the Explore data and is not compatible with pairing to the Garmin Explore smartphone app."
I thought that I understood the first sentence, but I really don't. With the device in hand, I can't find this 'pre-installed ... Garmin Explore information'. What the second sentence seems to mean is that the Garmin Drive app that you load onto your phone will interface, via BlueTooth, to your XT. It can sync data between the XT and the Explore app that you can load onto your phone/Android device or onto your ChromeBook. However, you can't pair the XT to Explore directly. Perhaps this 'pre-installed with Garmin Explore information' is the ability to make and participate in the interface between Drive and Explore. OK, that seems surmountable, if not useful.
Reading the user manual, though, would lead one to believe that it is possible to export data out of BaseCamp and import it into Explore. Being able to move some of that data from Explore into the XT might have some utility, especially if you could edit the data in Explore.
Exporting data from BaseCamp is trivial. These are the instructions for importing data into Explore:
Login to explore.garmin.com
A Garmin Explore account is required to login to explore.garmin.com.
Select the Map tab
Click (the import icon)
I have to go try this.
I have not yet begun to give up...
Select the Map tab
It seems that the Explore website is somewhat of a moving target. www.explore.garmin.com worked the first time, but was unreachable the second time. https://us0.explore.garmin.com/ seemed to work better. Shrug.
I exported two routes from Basecamp. One was a day-long ride and the other a 4000-mile route across the US. After going to https://us0.explore.garmin.com/and importing the routes they appeared on the Explore app on my phone. (and yes, it is confusing to have to use an Explore Website and an Explore app).
Going to the XT, I clicked on 'Where To?' and then 'Explore' (in truth, I madly clicked all over the damn thing before finally clicking on 'Where To' and finding 'Explore') and the routes were there.
Any route that is imported into Explore gets reduced to no more than 200 points. When I opened the short route in the XT it took whatever was there and recalculated it. It didn't do a perfect job of calculating the route.
You can't build a routable route in Explore. You can dump stuff from BasceCamp into Explore and get it onto your XT via the Drive app, but those routes will be comprised of 200 or fewer points and the route that the XT calculates from those points may not be very true to the original route.
Waypoints could work well, though.
This could bear some more lookin' into, but I'm not sure there is a great deal of utility in trying to move routes from Basecamp into Explore. They simply have too many points.
The next test was to crude out a route like in the old e-map days and see what could be done with that (I had rather high hopes that this would be worthwhile).
Beginning in the Explore app on the ChromeBook, I planned out a roundabout route from Redondo Beach to Sacramento by simply clicking on a start point, then a few random intersections up in the southern part of the California central valley, and then an end-point at the state capitol building in Sacramento.
Through the miracle of the Drive app and the Interwebz, the route found its way from the ChromeBook to the iPhone and to the XT. I opened the route in the XT and it recalculated the point-to-point route into a perfectly serviceable route from my house to the state capital, visiting all those random points along the way.
Then I built a route on my phone in a similar fashion, except I followed roads in a rather direct fashion up to San Miguel. It consisted of 5 points. The XT rendered it perfectly.
Who is online
Users browsing this forum: CommonCrawl [Bot] and 1 guest
