ConnectedRide Nav map color/ style problem
Having problems with your BMW navigator 6? then please post here with any sat nav, software, mount or cradle problems.
Krishna
Greece
Post by Krishna »
Hi guys, while connected to Wi-fi screen show colors and perfect, after disconnection - black and white... :!: . Navi 6 updated, new map installed, rebooted. 2 BMW centers do not know why and what to do. Please help.
Has liked: 392 times
Been liked: 854 times
Re: Nav 6 color problem
What theme do you have selected ?
Settings - Map & Vehicle - Map theme. (I think it will be)
Or it might be the display settings - which some models retain separately : when they are connected to power they are 100% bright, when not, they will dim as low as 10%
Krishna
Greece
Post by Krishna »
Map mode: Journey
Map style: Automatic
With wifi
With wifi
Without wifi
Without wifi
Thanks for the images.
Its not just the colours, the map is presented differently.
Did you check which theme was active for both screens. I cant see that is would change, but I don't mind clutching at straws.
Stumped. Completely.
Has liked: 422 times
Been liked: 237 times
That is a new one! I have never seen or heard of that one before
How old is the unit?
Krishna
Greece
Post by Krishna »
This is ConnectedRide Navigator 6 month. Problem start from the beginning. Looks like i need to buy cellular sim card...
Re: ConnectedRide Nav map color/ style problem
Your heading has changed - which might reveal why we are stumped.
My understanding was that the BMW Nav 6 was based on the Zumo 595. I also read that BMW parted ways from Garmin after that point.
The ConnectedNavigator appears to be a very different beast from the Garmins. I have no experience with it at all.
There are discussion on a BMW forum - eg https://www.advrider.com/f/threads/bmw- ... r.1671763/. You may have to register (free). You might get a more informed response from there. But keep tuned in here as there are a few AdvRider members that use our pages to glean information about the Nav5 and Nav6.
@lkraus - have you seen anything that might help ?
Krishna
Greece
Post by Krishna »
Thank u. Will try other forums...
