The Basecamp library can be accessed from different computers using a personal cloud storage service such as Drop Box, Google Drive or MS OneDrive. This document demonstrates the steps to set this up with MS One Drive.
Access Basecamp Library from multple computers
Re: Access Basecamp Library from multple computers
It's also possible with iCloud Drive using multiple Macs. Depending on how the Macs are set up, it's possible it's already been done automatically. It's also possible to access multiple libraries across numerous Macs.
That's good info. Since this is the How To Guide Section of the forum, should we anticipate a how-to for Mac from your?
Not having any luckBreezly wrote: ↑05 Feb 2020 04:05 The Basecamp library can be accessed from different computers using a personal cloud storage service such as Drop Box, Google Drive or MS OneDrive. This document demonstrates the steps to set this up with MS One Drive.
https://www.newenglandriders.org/GPS/Ba ... 0Share.pdf
Error 404 - Page NOT Found
New England Riders have revamped their web pages, try here https://www.newenglandriders.org/learn-basecamp/
Just to clarify this a little, the link to all the GPS articles on the NER website is:
https://www.newenglandriders.org/category/gps/
This is where you will find the write-up on accessing Basecamp Library from multiple computers.
The Basecamp tutorials are located at: https://www.newenglandriders.org/learn-basecamp/
I’ve got a question about this.
I’ve created a bunch of different databases.
Example:
One for Europe
One for DirtRides
Another for FJR Rides Local
So on and so forth.
In each data base I have my filing system set up with folders and lists.
I don’t want to lose the hierarchy of my folders and lists.
Will the process (as shown in the linked document above) work for keeping all of this in tact if I accidentally lose BaseCamp?
Example:
One for Europe
One for DirtRides
So on and so forth.
Not sure which part you're referring to but each data base contains two important files, AllData.gdb and FolderData.gfi
Provided those are copied you'll be ok as they contain the data and folder structure
Who is online
